$200 Project, Need Workflows Built For AI SaaS Platform
I’m working on an AI-powered marketing SaaS, and I need help building the backend workflows in Bubble.io. I’ve got most plugins installed and the structure ready — just need a Bubble expert to wire it all together.
Budget: $200 total
Timeline: 7–10 days
Tasks:
  1. OpenAI integration (generate content)
  2. Content scheduling and Automation (via Make.com or native workflows)
  3. Email Marketing Automation (using Rich Postmark Email plugin)
  4. Dashboard with Modern Charts to show content performance
  5. Role-based access setup (admin vs user)
Plugins already installed: OpenAI, DALL·E, Make.com, Rich Postmark, Modern Charts, Role Access, and a few others.
If this sounds like a fit, drop your portfolio and let me know your availability! Thanks!
check your DM
Honestly, if you want everything listed, well built and in this timeline… better to add a 0 to your budget… or built it yourself…
Be careful with what you will get as offer…
Are you a certified bubble user?
I have not done the bubble certitifcation yet but i have a couple of projects i have worked on
here are the project:
business-to-business bubble application built with complex workflows
  1. web3 ambassador programms
  2. SHOPCO
Bubble plugin built
  1. connect-wallet-modal Plugin | Bubble
I’ll send over my app that I’m working on. Show me what you can do, if I like it I’ll pay you the $200. It needs to fully work without any issues.
okay .
Sorry, I won’t be able to do this. I tried to add a collaborator, I couldn’t because I’m on a free plan.
you can add collaborator in free plan .
Here is how you go about it
1.Navigate to settings,
2. click on collaboration:
Then you will see the region circled with red at the bottom of the page
check the guide below
What’s your email?
Also could you create a private channel to discuss about project update @punaboy.mkk
