A Better Way to Build Plugins!
BubbleSurf-ezgif.com-video-to-gif-converter
I recently built a new tool that’s helping the cohort build even faster!
Before now, our regular workflow was to generate plugin code with Cursor, then manually copy and paste it into the Bubble plugin editor.
It worked, but it was time-consuming and repetitive.
So, I built Bubble Surf, a tool that automatically syncs your generated code straight to the Bubble plugin plugin editor, eliminating the copy-and-paste step completely.
Now, our cohort members are building faster, testing instantly, and iterating smoothly, exactly how it should be.
Bubble Surf is currently available exclusively to cohort members, and the results have been incredible so far.
If you want to learn the same structure and workflow we’re using to build powerful plugins in record time, now’s your chance to join.
Join us
