$$ a little help! just takes 1 min :)
hello it puts empty. im trying a lot of things i have thiss now. (the appdata readmision risk is working)
What is happening is that you are creating a new item and seems to work. Great, but later when you try to use that data, you are searching for the first item in your database. Probably that item is empty. You need to do the following:
Open AI Call → Create item → Display Data in a group → Use the parent data.
okey i have this. im trying to put ‘s readmission-risk. but still not working.. Thanks for yout responses
i have to go to work, i will retourn in hours thanks!
Change the group data to SocialAssesment and the data should display ok.
Just takes 1 min. … 4 days later.:rofl:
Sometimes coaching is faster.
yeah i was thing that is something simple haha! you can solve this too? i still need the help
Its still no workings on the previus . thanks for your patience. i have this . on the data is returning the info
What does the search results in debug mode show now?
okey ya lo he podido solucionar, gracias a todos y todas!!
What was the problem? Share the solution if possible so others can be helped later
