A little help with Designing a simple design feature
Hello fellow Bubblkers, Im pretty new to Bubble and i’m trying my hand in the editor.
I want to design the above featured menu selection but i’m not sure exactly how to design it, so if anyone can help out it would be much appreciated
I think you could replicate it using the same functionality as the Tab element. So using a custom state with 4 values.
You would need to be clever with the borders to make it work, so the lower “main” group would not have a top border. Then you control the tabs lower border on the conditionals so that you open up the bottom of the tab when it is selected.
Thank you so much, I will get to work on it right away and post my results!
