Algolia Facet Dropdown - Problem trying to integrate it via Plugin
I’m trying to integrate the Algolia Facet Dropdown (see Facet dropdown with InstantSearch.js | Algolia)
via a custom plugin as an element.
When the element loads the console is bringing the following error:
Element AlgoliaFacetDropdown - The plugin Algolia UI-Widgets (testing) / element Algolia Facet Dropdown threw the following error: TypeError: Cannot read properties of null (reading 'querySelector')
I’ve tried a lot already but nothing has helped so far. E.g. I waited until the page has loaded with
$(document).ready(function(){…});
I have also tried the code outside of bubble and there it works without problems.
There must be something specific about bubble that leads to this error.
What I can say from my analysis is, that it is most propable not a timing problem with the page load. The problem is, that the algolia widget is not added to the page at the time where it has to be there. So something hinders it from doing it.
The plugin code is the following (update function):
function(instance, properties, context) {
if (!window[`${properties.container_id}_run`]) {
    window[`${properties.container_id}_run`] = true;
    instance.canvas.append(`<div id=${properties.container_id} />`)
    // utility functions
    function hasClassName(elem, className) {
        return elem.className.split(' ').indexOf(className) >= 0;
    function addClassName(elem, className) {
        elem.className = [...elem.className.split(' '), className].join(' ');
    function removeClassName(elem, className) {
        elem.className = elem.className
            .split(' ')
            .filter((name) => name !== className)
            .join(' ');
    function capitalize(str) {
        if (typeof str !== 'string') return '';
        return str.charAt(0).toUpperCase() + str.slice(1);
    //Dropdown.js
    const CLASS_OPENED = 'ais-Dropdown--opened';
    const CLASS_BUTTON = 'ais-Dropdown-button';
    const CLASS_CLOSE_BUTTON = 'ais-Dropdown-close';
    const cx = (...args) => args.filter(Boolean).join(' ');
    function createDropdown(
    baseWidget,
        cssClasses: userCssClasses = {},
        buttonText,
        buttonClassName,
        closeOnChange,
        // Merge class names with the default ones and the ones from user
        const cssClasses = {
            root: cx('ais-Dropdown', userCssClasses.root),
            button: cx(CLASS_BUTTON, userCssClasses.button),
            buttonRefined: cx(
                'ais-Dropdown-button--refined',
                userCssClasses.buttonRefined
            closeButton: cx(CLASS_CLOSE_BUTTON, userCssClasses.closeButton),
        const makeWidget = instantsearch.widgets.panel({
            cssClasses,
            templates: {
                header: (options) => {
                    const { widgetParams } = options;
                    let text;
                    if (typeof buttonText === 'string') {
                        text = buttonText;
                    } else if (typeof buttonText === 'function') {
                        text = buttonText(options);
                    } else {
                        // See if the widget has `attribute`
                        const attribute =
                              widgetParams && widgetParams.attribute
                        ? capitalize(widgetParams.attribute)
                        // Get the number of refinements if the widget has `items`
                        const nbRefinements = (options.items || []).filter(
                            (item) => item.isRefined
                        ).length;
                        // Format the button text
                        text =
                            nbRefinements > 0 ? `${attribute} (${nbRefinements})` : attribute;
                    const classNames = [cssClasses.button];
                    if (typeof buttonClassName === 'string') {
                        classNames.push(buttonClassName);
                    } else if (typeof buttonClassName === 'function') {
                        classNames.push(buttonClassName(options));
                    } else if ((options.items || []).find((item) => item.isRefined)) {
                        classNames.push(cssClasses.buttonRefined);
                    return `
                        <button type="button" class="${cx(...classNames)}">
                        ${text}
                        </button>
                footer: `<button type="button" class="${cssClasses.closeButton}">Apply</button>`,
        })(baseWidget);
        return (widgetParams) => {
            const widget = makeWidget(widgetParams);
            let cleanUp;
            let state = {};
            // Return a modified version of the widget
            return {
                ...widget,
                init: (options) => {
                    const rootElem = document
                    .querySelector(widgetParams.container)
                    .querySelector('.ais-Panel');
                    const headerElem = rootElem.querySelector('.ais-Panel-header');
                    const closeButtonElem = rootElem.querySelector(
                    '.' + CLASS_CLOSE_BUTTON
                    const open = () => {
                        addClassName(rootElem, CLASS_OPENED);
                        // This 'click' event is still being propagated,
                        // so we add this event listener in the next tick.
                        // Otherwise, it will immediately close the panel again.
                        setTimeout(() => {
                                    state.windowClickListener = (event) => {
                                    // Close if the outside is clicked
                                    if (!rootElem.contains(event.target)) {
                                    close();
                            // Add an event listener when the panel is opened
                            window.addEventListener('click', state.windowClickListener);
                        }, 0);
                    const close = () => {
                        removeClassName(rootElem, CLASS_OPENED);
                        // Remove the event listener when the panel is closed
                        window.removeEventListener('click', state.windowClickListener);
                        delete state.windowClickListener;
                    const isOpened = () => hasClassName(rootElem, CLASS_OPENED);
                    const toggle = () => {
                        if (isOpened()) {
                            close();
                        } else {
                            open();
                    // Add a click listener to the header (button)
                    const buttonListener = (event) => {
                        if (!event.target.matches('.' + CLASS_BUTTON)) {
                            return;
                        toggle();
                    headerElem.addEventListener('click', buttonListener);
                    closeButtonElem.addEventListener('click', close);
                    // Setup a clean-up function, which will be called in `dispose`.
                    cleanUp = () => {
                        headerElem.removeEventListener('click', buttonListener);
                        if (state.windowClickListener) {
                    // Whenever uiState changes, it closes the panel.
                    options.instantSearchInstance.use(() => ({
                        subscribe() {},
                        unsubscribe() {},
                        onStateChange() {
                            if (
                                isOpened() &&
                                (closeOnChange === true ||
                                 (typeof closeOnChange === 'function' &&
                                  closeOnChange() === true))
                                close();
                    return widget.init.call(widget, options);
            dispose: (options) => {
                if (typeof cleanUp === 'function') {
                    cleanUp();
                return widget.dispose.call(widget, options);
// Creation of the refinementListDropdown widget
const refinementListDropdown = createDropdown(
    instantsearch.widgets.refinementList,
    { closeOnChange: true, }
window.search.addWidgets([
    refinementListDropdown({
        container: `#${properties.container_id}`, // the CSS Selector of the DOM element inside which the widget is inserted.
        attribute: 'Classification',  // the name of the attribute in the records.
        searchable: true,    // whether to add a search input to let the user search for more facet values.
        showMore: true
The problem arises at this point:
Does someone has a clue about what could be the source of the problem?
