Suddenly (between today and Friday) the “Animate Element” workflow decided to stop working. I thought that I had inadvertently screwed up some larger process that affected all kinds of parts of my app, but it turns out that any workfow using the animate element action is suddenly broken. The test version is just stuck loading infinitely whenever a workflow reaches an animate element action. Changing to a conditional statement paired with ‘this element is visible’ works completely fine.
Hey bubble any updates? This bug hasn’t been fixed…
Fixed. The issue was a pluging that was trying to overwrite jquery. Plugin deleted, problem solved.
