Announcing Buildprint AI: Build on Bubble with Claude Code and Codex šŸŽ‰
@georgecollier In build mode, Is it possible to show the number of tokens used and time at the end of a build request?
We will at some point, neither Claude Code nor Codex surface those easily tho which is why it hasn’t been done already
Can’t we relay on the usage object that’s returned by Claude/Codex to show output_tokens?
{ "id": "msg_...", "type": "message", "role": "assistant", "content": [...], "model": "claude-sonnet-4-6", "stop_reason": "end_turn", "usage": { "input_tokens": 25, "output_tokens": 142, "cache_read_input_tokens": 0, "cache_creation_input_tokens": 0 } }
a level of financial security one can only dream of
man the automated tests are so cool
This is super dope! Man, I wish I had time to get Buildprint rummage through my app. There’s just so much project red tape and paper work that I am dealing with. I’m only able to work on smaller updates and fixes.
As much as the AI agent is the way forward (and the way Bubble should have implemented theirs) Buildprint’s Bubble app observability and troubleshooting tools and capabilities are the real wins for me.
Buildprint’s features are true to Bubble’s spirit of small teams working on large projects. I’m still solo deving and I haven’t tried yet but I can see troubleshooting becoming leagues easier. Documentation is also something I’ve been procrastinating but from what I’ve read of what Buildprint can do, I’m actually excited to start working on documentation!
Upgrades to agent and automated tests quality
Today I’ve made a bunch of improvements to how Buildprint’s agent can explore apps and build new features. You should notice Buildprint be able to locate things easier in your application, and more accurately build new features that it hasn’t previously seen in your app.
  • Buildprint can now see linked elements/workflows (e.g when looking at a workflow, it can also see the element that triggers it, or when looking at an element, it can see all workflows that use it). This lets it efficiently explore logic relationships in your app.
  • Comments now supported for API Connector calls and groups
  • Fixed issue with diffing history of same version
  • You all now have auto-generated project summaries based on your app. You can review and update them from Project settings.
  • GLM 5.1 has been made available
  • Buildprint will be less likely to omit optional fields that ought to be filled when editing
  • Buildprint will be better at implementing actions, expressions, and other logic that it has never seen before
  • Tests will now run moderately faster, and agents have improved guidance to deal with common Bubble elements like date picker and searchbox which aren’t super straight forward.
  • Buildprint is now better at writing its own tests and docs have been updated with more best practices here.
Killing it as usual
@georgecollier Can we add a feature that converts review comments into a plan then take it to the chat for the agent to build?
Hey @georgecollier, can you give our application access to editing/build mode? Can’t really do much until then.
Editing will be released to everyone in a couple of weeks
Until then, there’s a lot you can use Buildprint for:
  • triaging prod issues
  • planning new features
  • diagnosing bugs
  • implementing automated no code tests
  • identifying regressions when merging branches
  • setting up alerts and monitors for events using the observability tools
Thanks @georgecollier for expanding the Best Practices
You mention ā€œRun reviews on every branch that touches high-risk areas: payments, authentication, user data, or privacy rules.ā€
But why not run a review whenever Buildprint modifies anything (not limited to high-risk areas), just to be sure Buildprint didn’t expand the scope from what I’m expecting?
Sure, run reviews on whatever you want
It’s more of an ā€˜at least’ run reviews on those branches. But for straightforward changes you might not want a review - ultimately you don’t want to slow down your deployment process with procedure that’s not always going to be necessary
is this the first half-decent open model? sounds like a good option for ā€œchange a bunch of stuff exactly according to X planā€
Yeah but its same price ballpark as GPT 5.3 Codex which is probably better
hmm surprising, usually open models are dirt cheap and that’s the whole appeal
It’s because GPT 5.3 Codex’s cache read price is actually lower than GLM 5.1’s
Upgrades to edit speed and Buildprint token efficiency
This update targets speed and token efficiency when Buildprint is completing edits on your application
  • Previously, Buildprint would ā€˜test’ its edits to see if they’re valid. It then saw the JSON result. Then if happy, it would apply the real one again and have to write out its edits in full again, and then see the result again. Thats a lot of tokens! Now, we let Buildprint re-use draft edits without having to write them all out again. We also no longer surface the resulting app JSON (as it can already access it if it needs it using other tools). Less write tokens when doing edits, and less read tokens when applying them.
  • Buildprint can now create, list, and restore to savepoints itself (the last two are new)
  • Buildprint can now clone an entire page + copy UI from anywhere in the app without having to write it all
  • Removed support for / paths when exploring app JSON as it could cause agent confusion
Anyway, who wants first-class support for mobile native apps with Buildprint?
Well, I guess the next step is to just build your own platform :grin:
I would hope Bubble’s AI gets going a little better than it is. I still have confidence it can.
I built my own AI that scans my app and gives me feedback…
probably could be improved, but it works for now.
Haven’t tried Buildprint yet, but with all the positive reviews, I think I should
nothing to lose by trying
