I just bought Linear because of Buildprint, I used clickup then plane, and mannnn Linear is nice. Can we have a feature req board somewhere for Buildprint? I have more ideas
Current list:
webhooks for the technical and product changelog
queryparam support for the web ui’s prompt input box (so in Linear, I can add a custom issue coding url that can add in the issue context when i click open in Buildprint)
Buildprint now supports integrating MCP servers into Buildprint Web. You can connect almost any MCP provider.
Popular MCPs include Github, Slack, Gmail, Google Docs and more.
For security, we have removed support for shared ‘write’ conversations. i.e, if you share a conversation with a team member, they will be able to read it but not send messages (else they may be able to use your MCP connections).
We’re removing support for non-billable read-only guests from September 1st. This is mainly because not many people use the feature, and it’s kind of hard to understand. This simplifies the billing. Any affected workspaces receive an email.
It’s a really cool feature. It would be nice that we can select the language for all the explanations. I have no problem with english, but I’d rather to have it in my mother tongue language.
FYI: Received confirmation that Buildprint does count as a qualifying agency collaborator after 50+ days because it is classified as an agency user/seat. So it does get agency revenue attribution
@georgecollier Recently I’ve noticed that using Opus in a session tends to stall after 30 mins or so. I’m forced to start a new session. It was working well a few days ago.
So does that mean as an agency, if I use Buildprint on a client project, my agency loses half of its attribution? This could keep my agency from potentially moving from silver tier to gold tier as bubble would be attributing less revenue to my agency?
Not sure about historical attribution & it depends on how long you’ve had Buildprint connected to an app, but yes, correct. I believe they are looking into making an exception going forward, will report once I hear back.
I have done several merges to live since the radar feature was released but am not getting the changelogs (I am requesting the techincal and product changelog on each merge to live). I am using both the slack channel integration and email. I work primarily with the CLI (v 4.3.1) via Codex. Any suggestions?
