Thanks for flagging, a fix will be pushed today
In case people are curious about how different models perform on Buildprint:
- Fable 5.1 - SOTA, particularly good for UI
- GPT 5.6 Sol - very good all rounder
- Opus 5 - can take shortcuts
- Grok 4.6 - very good all rounder, just not as good as 5.6 Sol/Opus
- GPT 6 Astra - overcomplicates and not better than Fable 5.1 for UI, consumes rate limits heavily
- GPT 5.6 Luna - good for understanding/research but not for implementation
Thanks for the insights - interesting to see. On the UI front, is there any difference in results between using the Agent and the CLI (now that the CLI has been upgraded)?
CLI is recommended if you are a power user and want the most control over your agents
Faced the same issue, reverted via published versions of the plugin. Filed a bug report.
Run bulk workflows, better UI gen, office hours
- Buildprint can now run bulk workflows it creates in both test and live (if youâve granted permissions in the editor). This means Buildprint can now do data migration itself, without you needing to manually do so in the editor.
- A bug which meant group focuses would often stretch to the height of the screen has been fixed
- Office hours @ Buildprint Office Hours ¡ Luma, weâve got 40 signups so far!
In my experience, Opus 5 is unreliable, overly complicated, and âspeaksâ in a disjointed way. Iâve reverted to Opus 4.8. Buildprint via the CLI in Opus 4.8 seems to work fine. Maybe it should be offered through the app?
I see that both Fable 5 and Fable 5.1 are available.
Does this mean that BuildPrint allows you to do this in a way that avoids significant WU consumption even with the smallest bulk operation, once the table is well-populated ?
That would be so great, given the challenges involved in maintenance and system evolution.
@georgecollier still loving BP and using it constantly, thank you!
Quick question, I am using BP in VS Code (Fable) and canât update to any version above 5.0 with my project. Submitted a bug report and my agent also suggests mentioning this:
On Windows 11 (Buildprint via npm, Node global install), every 5.x release since 5.0.4 fails the same way. Confirmed again today on 5.0.9, tries a project clone and then fails.
The folder it leaves behind isnât recognized afterwards (sync says âThis directory is not a Buildprint workspaceâ). Earlier 5.0.x runs showed the underlying cause as the SQLite index never finalising (EPERM on fsync). 5.x also doesnât read a 4.3.1 workspace, so thereâs no upgrade path other than a fresh clone, which is the thing that fails.
Another quick question - I just tried Fable in Buildprint Web instead of VS Code and the UI design was much better at using the mockup design I gave it. Is this related to the version or will the design always be better from Buildrint Web even when on the latest version?
Thanks, I know about this and am working on a fix but if you try again in 12 hours or so once i release 5.0.10 then it should work.
No, they both run the same thing behind the scenes (Buildprint CLI). The difference is random chance, or Buildprint Webâs built in test stuff (if you use the /test skill then itâll test its work in the browser which is hugely recommended for UI work).
Either way, you can build mockups directly in Web using /prototype, itâs really cool!
very diplomatic
Fable 5.1 Low for BubbleScript
strongly recommend
One of our clients is struggling to migrate off of bubble because theyâre building new features so fast with Buildprint that their migrated codebase canât keep up!
On this, I have a couple of observations:
Buildprint will overcomplicate stuff and do things which are dumb if you look at them in the editor. e.g option:merged with option:merged with option instead of All Options:filtered. So when theyâre vibe coding with Buildprint, it technically works, but is adding tech debt.
But itâs also true that AI does shit like this in code. You just donât notice it. In Bubble, you notice it. So, see all the dumb shit Buildprint does that technically works but is objectively dumb? Thatâs every AI-generated codebase where people donât look at the code!
How many more tokens does Fable 5.1 Low use compared to Opus 5 Medium on buildprint bench?
It uses less, because itâs less verbose in general and lower reasoning level.
It would be great to have the ability to flag a conversation
For what?
- When working on heavy features, one conversation can last for a while
- Some conversations can host documentation that you want to easily retrieve.
(1 and 2 can be combined)
In the meantime, you can open various other debugging conversations that are âshort termâ conversations and those initial conversations can become lost in the middle.
Is this issue resolved?
