API recurring event - How to test out? Please help
Does anybody know if there any way I can test out if a recurring mail(via recurring API workflow) is being sent WITHOUT upgrading the plan until the app is finished?
Thanks so much
Fred
Hi @freddc83
As far as I know that’s not possible. I had the same issue with API Workflow. You need to upgrade your account to start using benefits from other type of plans regardless your app is running or not.
