AWS Face Liveness & Face Matching in Bubble.io — Custom Integration Approach
Hey everyone! :waving_hand:
I wanted to share my experience integrating AWS face verification capabilities into a Bubble.io application.
The project involved two key parts: live face detection and face comparison, with different integration approaches for each.
1. AWS Face Liveness Detection
I initially developed and tested the face liveness functionality in a Next.js environment.
After testing the initial implementation, I adapted the JavaScript approach for use in Bubble.io, working through the differences between a React-based component and Bubble’s custom HTML/JavaScript environment.
The goal was to detect whether a real person was present in front of the camera and handle the verification session and results.
2. AWS Compare Faces — Workflow-Based Integration
For face comparison, I used a reusable, plugin-style workflow in Bubble.io rather than building the entire comparison process directly into the frontend.
The workflow was designed around comparing a reference image with a captured face image using AWS Rekognition’s CompareFaces operation.
This approach helped separate the face comparison logic from the UI and made the integration easier to reuse within Bubble workflows.
3. Technical Challenges
  • Adapting the AWS Face Liveness component for Bubble.io.
  • Managing liveness sessions and verification responses.
  • Passing the correct reference and captured images into the face comparison workflow.
  • Handling similarity scores, match results, and unsuccessful responses.
  • Keeping AWS credentials and sensitive operations on the secure backend.
Key Takeaway
This project explored two different integration patterns in Bubble.io: adapting a React-based face liveness experience and using a reusable workflow for AWS face comparison.
I’m interested in hearing from other Bubble developers who have integrated AWS Rekognition or similar identity verification services.
