Banner removed warning when using translate
I made a test app to see if it was possible to translate a bubble app with the google translate widget, and it did except from the fact that I got a warning from the platform where it thinks that I have removed the bubble banner from the page, which is not the case.
Make sure the content of the banner (the text) isn’t being translated. You should set up things to only translate your page. (Note also that when you’ll be on a paid plan there won’t be a banner any more).
Thanks, yes I understand that this issue only exists on the free plan, but unfortunately, the tool does not offer a way to exclude the banner. So this means then that page translation with the google translate widget currently only works with the paid plans.
