Base64/URL could not be read
I can’t understand why this error occurs so that the call api doesn’t work. There is another call with an identical function that works without problems (function of sending an image to a phone number). Can someone help me?
Screen Shot 2024-02-28 at 13.07.05
What did you set for URL?
183 / 5.000
Resultados de tradução
Resultado da tradução
In body parameters (url, message and telephone) I set all values in blank, just like exactly in the other call (which works normally with the same function of sending an image to a cell phone number).
If you set them empty/blank… this is probably not what the API endpoint expect and you need to fill them. The error tell you exactly what is the problem. Send a base64 or url to the endpoint to be read.
