Hi I new to bubble.is and also to API´s I would really apreciate help setting up the API from sketchfab, basically I want to get uid from the sketchfab platform to display it in a bubble app:
I have triyed the BIM calculator example and the Etsy exmaple but the uid im getting is not the one that I want:
Here is the GET URL: https://api.sketchfab.com/v2/models/{uid}/status?token={token}
Ass you can see in the URL after “uid” is “status” so I dont know haw that goes.
The uid im putting is: c52ea05222234b6eb561a6dc57161d68
Here is a screenshot of what im doing.
Thanks a lot if someonw could guide me, since im a newie in the API´s world.
Also Im in the Sketchfab API developers page and it says this:
You must perform an HTTP POST to https://api.sketchfab.com/v2/models.
The uploaded file must be in one of the supported formats (or a compressed archive).
Parameters
The POST request accepts the following parameters:
token : your Sketchfab API token
modelFile : the model you want to upload
name (optional) : model name
description (optional) : model description
tags (optional) : list of tags separated by space
private (optional) : if set to True, then the model is private (requires a PRO account)
password (optional) : if private is set to True, you can add a password to protect your file (requires a PRO account)
isPublished (optional) : defaults to True; if set to False, the model will be uploaded in Draft mode
We require the parameters to be posted separately as a multipart POST, not JSON or XML
What is a multipart POST, not JSON, and my question is, it is supported by bubble??
Thanks
