Best way to handle contracts with templates and uploads in Bubble?
Hi Bubble community :waving_hand:
I’m building a Contracts module in Bubble and would love advice from anyone who has done something similar.
Key requirements:
  • Convert an accepted offer → contract with pre-filled data (contractor, role, rate, dates)
  • Create a contract from scratch
  • Allow employers to upload their own contracts (PDF/DOCX), including multiple documents (e.g. MSA, SOW, NDA)
  • Provide standard contract templates (US and Canada)
  • Store contract terms as structured metadata linked to a Job or Offer
  • Support contract versions (e.g. SOW v2 for renewals while keeping the same contract)
  • Contract storage and retrieval
Main question:
From a Bubble architecture point of view, is the most realistic approach to treat a contract as:
  • a database record (status, parties, dates, terms), and
  • attached document files (generated from templates or uploaded as-is)?
Have you used any document generation tools (PDFMonkey, Documint, DocxBuilder, etc.) for this?
Any lessons learned or things to avoid?
Thanks in advance
Just sharing my experience designing a similar process. For digital contracts:
  • it’s important to hash final versions. Match this hash clientside at important points such as during signing and export.
  • you can go the extra mile and keep draft and final versions as seperate datatypes.
  • uploaded or generated documents should also be hashed simlarly
  • final contracts and attached documents should be immutable
  • make sure your audit trail keeps track of changes, exports, draft to final updates etc. The audit trail should be easily accessible.
Your approach is spot on. Create a main ‘Contract’ data type for the high-level relationship, and a separate ‘Contract Version’ data type to hold the actual files and structured terms. This makes versioning (e.g., SOW v1, v2) clean and links everything to one parent contract.
