Announcing Cloud Companion
The next edition of Better Uploader will also release with a new companion plugin called Cloud Companion
Cloud companion is an expansion pack for Better Uploader which will include many useful features such as…
- compress JPG’s, PNG’s and BMP’s by giving a quality number from 1 - 99
- extract text from a text file
- apply filters to images
- resize images
- combine images
- video compression
…and more to come!
Cloud companion is designed to work in tandem with Better Uploader. Wondering How?
Remember Better Uploader’s Raw Data exposed state (useful for previewing files)? Well, by passing that Raw Data to Cloud Companion’s actions (executed in the workflow tab) you will be able to leverage those functions and Cloud Companion will take care of the rest
I wanted to let everyone know that I really appreciate the positive feedback that I received for Better Uploader. Cloud Companion will only cost 14$ and is a completely optional plugin. All of Better Uploader’s features will continue to be free and I am comiting to support both plugins.
If you’d like to support the work I do, I 100% recommend getting Cloud Companion!
Cloud Companion will release in the next 2 to 3 weeks (it’s almost done, it just needs to be polished)
Cheers!
@brad.h
