The Air Date Time Picker has the setting for unavailable dates, just check out the plugin element and you’ll likely find it.
If you are trying to create a cross out of unavailable date for a custom calendar you build with repeating group and other elements, what I did in mine was used a shape element, made it only 1px wide and used the rotate feature to rotate it 45 degrees.
