Bubble chart HELP
so the bbuble chart plugin is great for customisation but when i try customise the colours of the pie and donut charts this is not do able.
heres a picture for reference
any help many thanks
995decf46a1345aae1a2a5161f4e3edc
No… it really isn’t…
You can’t really customise it at all (as you’ve already discovered).
There are other (much better) plugins available for charts (some free, some paid), or if you’re comfortable using JavaScript, and/or don’t want to pay for a plugin, you can use a library like Chart.js directly to give you full freedom of customisation, which is what I generally do for charts.
But for sure, check out the plugin marketplace for some chart plugins with better customization options.
ok thanks very much adam only issue im seeing with other chart plugins is that they dont have previews
