Bubble Editor Ideas and Suggestions
+1 early on this was very confusing for me.
Free categorization on the plugins need to be improved, “One Time Payment” option can be added under Free/Premium
Option to disable the plugin would be nice, rather than uninstalling and removing all plugin elements from app
Deactivate the performance warning… I’ve literally checked the console hundreds of times over the last year thinking that something’s wrong, just to be met by a bunch of warnings all saying the same thing: please upgrade… it makes sense to give a heads-up on performance, but seeing that console error light up is like constant cry for wolf. Move the warning into the Capacity tab instead.
Negate value operator for numbers, turning 5 into -5.
The +hours, +seconds etc for date fields is very cumbersome to use if you want to subtract something, and instead of adding a minus operator to all of those fields, a negate value operator could let us subtract hours etc. without going through custom fields etc.
(oh, and add +minutes!)
Thank you so much, @klaas.vanhoeck1, @petter, and @melon! Your ideas were added as numbers 44 through 49! :relaxed: :+1:
Hey Faye! Great list you got here! Also really cool to see that Bubble implemented a lot of them recently. In hopes of catching their attention once more, I offer this suggestion - Ability to set the height of a group / repeating groups to the height of the viewport.
There are many examples of people looking for this on Bubble in the past:
This has 40 hearts
This one is pretty recent: Dynamic height Repeating group
This feature would allow us to build sleeker, sexier apps. Plain and simple. Take for example Evernote which could near be built with two repeating groups and 1 regular group, if only they could span the entire height:
ms5ub9XCeQ
And let’s be real, the Bubble editor itself is very functional thanks to repeating groups and regular groups that span the veiwport. Below I show the plugins tab which could be recreated with 1 repeating group and 1 regular group, if only they could span the entire height. Ahh, bask in all that resizable height glory:
ezgif.com-optimize
A client app I’m creating could really use this and I am sad cat there’s no easy way to do it :crying_cat_face:
@allenyang bumping for #20 / the linked suggestion - 14 Likes strong!
Having a way to quickly identity elements that are overlapping, for example by showing their borders in red when a button is held down or a setting activated.
On big SPA’s, two out of 100 groups overlapping by a single pixel can wreak havoc. Would be a timesaver to be able to spot them quickly :heart_eyes:
An addition for simultaneously edit multiple elements:
Change ‘fixed width’ and ‘minimum width’ of multiple elements.
When making a whole page responsive with a lot of text elements would be easier if we can change this setting all at once.
Thank you so much for the awesome suggestions, @zelus_pudding, @petter, and @klaas.vanhoeck1! :slight_smile: :raised_hands: Your suggestions were added as numbers 50-52!
Has been implemented. Great!
screenshot-bubble.io-2020.03.16-14_47_11
Make Clear all reset to an empty field, instead of …edit me…
2020-03-19_09-51-30 (1)
Reading through, lots of great ideas here…Bubble dreams :star_struck:
I have a few ideas scattered together in this thread here that I think could be of some use to others as well:
But I’d really like to see the ability to add comments on a condition basis. So on a element that has many conditions, we can add a specific comment to the condition (not the whole element) with regards to its functionality. Granted its quite a niche request, but I’ve found a few times using a series of complex conditions and coming back to it, being puzzled. Commenting on the element works, but bit cumbersome, especially if the order changes.
Cheers
Without parenthesis available, this would be amazing if implemented :+1:
Awesome! :partying_face: Thanks for catching that that one was implemented, @Jici! :tada:
And thank you so much for the great suggestions, @petter and @luke2! I’ve added them as #53 and #54! :slight_smile:
Bubble based editor zoom hotkeys! Trying to get the right zoom percentage in the grid list is repetitive. Check Figma’s functionality for how easy it is to zoom in an out with a scroller :slight_smile:
Suggestion: Ability to “show” hidden elements in the editor by default - Even if they are not visible on page load.
We all know that hiding an element then showing when you need to is a great performance gain for your Bubble app - But it makes things clunky when you’re using the editor. Each time you load a page to edit that has hidden elements on page load, the element is invisible - Leading to large blank spaces on your editor page - Requiring you to manually un-hide each time.
For SPA apps, it’s a killer if you have 25 hidden groups on a page.
My Recommendation:
Example 1:
BEFORE:
AFTER (put an overlay on top of hidden elements, so when you open up a new page, you can SEE what all hidden elements you have without having to click into each one):
Example 2:
BEFORE: (Notice it’s just a large blank expanse…)
AFTER
How would it be done?
Make it an option in the Grids and Border menu - “Outline hidden elements”:
Notes:
  1. This would not apply to popups/floating groups. Recommendation is to start with groups/repeating groups first.
  2. Clicking on the eye icon at the top left of the outline would unhide it so you can rapidly edit right there.
This idea was brought to you by a co-worker who was tired of working on MVPs with me and going to pages with 10 hidden elements (for maximum performance) and wondering where the heck they needed to make changes! :slight_smile:
I completely agree!
If I can add my two cents, I often use overlay and collapsing groups in the same SPA. Having all hiddens to be visible would mean hiding a bunch of elements on editor load…
I suggest that the last visibility state should be used instead, so when I do an editor page refresh, we would find the displaying in the same state than before.
By the way congrats on the clear “fake-screenshots”! :slightly_smiling_face:
Not sure if someone suggested, but it would be awesome to have the ability to duplicate one data entry (this is cool when you need to test RG with more data instead of creating one by one).
