Bubble + Mercado Pago (Mercadopago - Checkout Pro Renato Asse Plugin): Webhook not returning external_reference
Issue Description: I am integrating Mercado Pago into Bubble using the Mercadopago - Checkout Pro Renato Asse Plugin. While the payment is created successfully and the webhook triggers as expected, I’m facing a critical issue when trying to identify the user.
The Problem: In my Backend Workflow, Step 1 (Consultar Notificação Payment) successfully receives the ID from the webhook. However, when I try to use the results of that step in Step 2 (Make changes to Empleador), the external_reference field comes up empty/null. Since the external_reference is missing, the search for the specific unique_id fails, and the user’s subscription status is never updated.
This is my workflow:
Frontend Workflow:
  1. Button “Elegir plan” is clicked.
  2. Step 1: Mercadopago - Criar preferencia
    • Notification URL: https://nanasperu.com/version-test/api/1.1/wf/mercadopago_webhook
    • External Reference: Current User's Empleador's Unique ID
  3. Step 2: Open an external website
    • Destination: Result of step 1's sandbox_init_point
Backend Workflow:
  1. API Event: mercadopago_webhook
    • Expose as a public API workflow: Checked
    • Parameter definition: Detect request data
  2. Step 1: Mercadopago - Consultar Notificação Payment
    • (path) ID_payment: Request Data's body id
  3. Step 2: Make changes to Empleador…
    • Search for Empleador (First item)
    • Constraint: unique_id = Result of step 1's body external_reference <— This is where it fails (returns null)
    • Field: subscription_active = "yes"
Has anyone experienced the Mercadopago - Checkout Pro Renato Asse Plugin not returning the external_reference even when the payment ID is valid? Is there a different way to fetch the payment details or a specific setting in Mercado Pago’s dashboard that I might be missing?
Any help would be greatly appreciated!
