I am working on a database for which I would like to create an app in which the existing data can be displayed, searched and filtered.
The database has a very simple structure, but the problem is its size: at the moment there are 46,000 entries and it cannot be ruled out that there will one day be around 100,000.
Is Bubble even suitable for such a task? If this is the case, I hope that you can give me some general recommendations on how to solve this problem.
So far, this database only exists as an Excel spreadsheet.
Well, I don’t know who told you that, but having a larger database doesn’t increase WU, so that’s incorrect. A larger database might be slower to search through, but database size has no direct bearing on WU.
On a side note, I definitely wouldn’t consider 46k, or even 100k, to be a ‘very large database’, I’ve built and worked with apps in Bubble with databases in those ranges have have never noticed any real issues with performance.
In fact the person how answered to my question replied: “It is but as the data grows more, the filtering and database operations will become more complex and will cost more WU than before. However, if you’re working with lots of data, I recommend you use Xano as your database with bubble. The response times are fast and you can perform complex queries and data manipulation.”
Another person said: “I personally have a few tables over 20k rows on Bubble databases and the WU are getting pretty high (couple million a month).”
Other people agreed that Xano (or Supabase) wouldbe a good choice with Bubble. Any ideas about why I should use those?
WU is a function of traffic/usage, NOT database size. WU for two similar apps with 10k rows and 1 mil rows respectively would be almost the same. They probably have an inefficient database structure or workflows…
No, if you’re primarily using an external DB and using Bubble as a frontend, you don’t use Bubble, because Bubble is shitty as a frontend because that’s not what it was built for. Bubble is good because of how the UI, logic, and database all link together.
