Button + icon element improvements
I had the same issue
I had the same issue. I need to put it inside a group just to enable this now.
Hopefully fixing soon
My fix is to wrap the button in a collapsible group for now.
This has been fixed, let me know if you are still seeing any issues
I tried this feature and I can only have the icon on the left with text on the right. Am I missing something? Would be beneficial to have the option to define where the icon and text alignment is.
@animisha45, took me a while to find as well. Click on the “Layout” tab and you can adjust the icon placement, button alignment, and gap between icon and text.
Ah. Got it. thanks.
