Hi All,
is anyone else experiencing an error where-by, when you calculate the :Distance from one place to another you get a completely incorrect result.
eg; the following shows that the calculated distance between these two addresses (right next door to each other) is 3,700+ Kms apart
I have documented it here, and it appears that this is probably an issue for addresses in Australia only, so any Aussies out there would be great if you can confirm this.
Would love to hear if anyone else has the same issue.
