Been stuck on this one for a while and I’m sure there’s an easy fix…
I’m trying to use API Connector with LiveWebinar.com so that I can use Bubble to programmatically cancel scheduled webinars.
I’m having difficulty with Oauth2 Custom Token and would appreciate any help! I keep getting a “Unidentified Index: grant_type” error when I try to initialize the call (I presume that’s how you test if you’ve correctly fetched an auth token?).
I have been stuck on setting this up also the past few days, so keen to see how this is resolved.
It seems that bubbles implementation of OAuth 2 is slightly unorthodox, and mapping of the archibot API to bubble as per their documentation throws up a few issues of authentication, as your secret should be use to request the token before any calls are made.
I started with a “None or self-handled” Authentication
Then I did a Post method as laid out in archiebot api documentation and was able to successfully generate an access token
I then had to copy and paste that token into my header. So when it says Authorization Bearer ACCESS_TOKEN, instead of literally ACCESS_TOKEN you replace that with the long chain of generated characters you just copied.
I’m still having trouble with doing the delete call
