Chart plugin with left and right y-axis?
Is there a chart plugin that allows a separate left and right y-axis?
This is the chart I’m trying to recreate:
Hi, Chart Tools does this
Thanks, Edward. Do you have an example of this somewhere?
Also, do you have an example Bubble editor I can take a quick look at? This is my first time using charts and I’d like to see how the data is injected into the charts so I can export it correctly from MATLAB.
Sure - here’s a quick demo that looks similar to your example and builds across two axes.
I just picked up your message on DM. We can talk there if you have follow-on questions.
Thanks
