Is it possible to assign a Class Attribute to cells in a repeating group? if not, any id how soon is this possibility coming to Bubble?
Don’t see how it would be possible to even implement that. Why can’t you use the index for your use case?
I need to create chips (tags). I was thinking maybe I could apply some CSS to achieve dynamic width of RG cells. I guess a Class attribute would make more sense in this case. Is it possible to have a class attribute for RG cells?
Each cell already has a unique id. You could do two things from my point of view.
Add a group that takes up the entire height and width of each cell and the RG and give that group a unique ID. Alternatively you could build a plug-in that modifies or adds an additional unique identifier to the cell. Most likely what you would want to do is add a data tag.
You can look for the Classify plugin if u still want.
I found this little gem of a plugin called “Chippify Repeating Group”. I tried it and it works very well. I faced no issues testing it in a test app. And it’s a really simple solution. A big thanks to the author
