Cloudfare deadline next week, need help
Hi All,
We just got an email saying we must check the “Enable Cloudfare” box in our domain and email settings. If we don’t do this by next week our site will not work properly.
We have a bare domain and our registrar is Go Daddy.
Anyone with a similar experience have feedback, or a link to a step-by-step for our situation?
I found a post from 2019 but it died in 2022.
Thanks for your help!
all you need to do is follow the instructions in the email and check the box in your settings :+1:
I can help if you want to book a session with me. :blush: I just updated my own site.
ok, just want to make sure this sounds right to you.
I toggled the checkmark within bubble to enable Cloudfare.
I was then shown (8) records to paste into our Go Daddy DNS records
(4) Type A @ ##.###.###
(4) Type A www ###.##.##
I then deleted the two blocked records there were already in our go daddy records (1) Type A @ and (1) Type A www
Since we have a bare URL, I then went to the DNS Forwarding tab in Go Daddy and setup our mysite.com to permanent forward to https://www.mysite.com
Sounds correct?
from the team:
we do the forwarding for them - all they’d have to do is update the A records and wait for it to propagate
