cmTts0 is not a possible option after convert to reusable element
Hi, maybe this will help someone
I converted a popup to a reusable element and was getting the following error on a number of workflows:
There wasn’t an obvious problem in the workflow but the workflow folder flashed for a second in red. The issue was that that old popup had workflow folders that were not carried over on conversion. The solution was to reassign the workflow folder.
