1 = Element
2 = FullCalendar
I donât understand. Thatâs not how you use the calendar. You have 2 calendars on here. The element is the calendar
Bafc - Calendar Element is the full calendar element that is shipped with this plugin
Youâd place the calendar element on the page and stretch it to the correct size and set the inputs and initialize that element.
I thought it was just like a helper.
So your full calendar is called BAFC-CalendarElement-A? Correct.
Just being clear on names will be helpful here
Calendar element is the full calendar instance
Calendar helper element has some extra data outputs that are⌠helpful
Iâm imagining you donât Have your data outs set correctly. Looks like an area in the docs that need updating. the examples may have been hard to follow.
Set them like this exactly.
Got it. So Iâm removing BAFC⌠element and have just one FullCalendar.
Thanks for clearing that up.
Iâm adding the text element to display the resources.
Will do. This is whatâs there:
You mean thatâs whatâs there now and youâll update it to match mine exactly?
So youâre in the know, the TSG data Types there are for use with the Time Slot Generator
Fixed:
Now Iâll try to print the resource list.
Look again. Calendar data doesnât match, mark. It really does have to match exactly to the picture I shared above.
I only see this one option to select:
Thanks for your patience.
Event array now shows up
Perfect! What we do here is set the data type for the exposed states.
So when you look at your array, do your events have the resources youâd expect them to?
Ok. Awesome. And what happens in resource view IF you leave the specific resource list empty
Like. Not an empty list but donât event set a data source for the specific resource list. Only set the event resource list. Not the specific resource list
Checking âŚ
