Connecting/Using SQL or MongoDB for Database
Hi there. Is it possible or has anyone used SQL or MongoDB to run a majority of their database?
I basically want to use bubble as a frontend and user management tool, but rely on a custom backend database.
My main concern is user data. If user data is saved on the bubble DB, can it be saved/accessed from an external DB?
Anyone?
I have the same question if anyone can do this!
