Copy / paste layout doesn't copy "keep aspect ratio fixed" check box
So if you do “copy special” on an image, then select “layout settings” and then “paste special” on another image, then select “layout settings” it copies everything except whether the box “keep aspect ratio fixed” is checked or not.
Should this not be copied as well, since it’s a layout setting?
