Create a canvas element using plugin editor
Hi everyone,
I have an image of a floor plan and I need to use the canvas elements to draw grids over it. The co-ordinates of the grid is fetched from an API response and the image of the floor is also dynamic. I’m try to build a plugin that takes in the image, gridpoints from the user and returns a canvas with the image and grid embedded inside it.
Can a solution be reached using a plugin or is there a plugin ready available for this purpose or any other way to achieve this. Your help is appreciated!
@keith
Hi Keith,
I don’t think this could be built in Bubble. We built a custom tool that does something similar and it’s quote a complex set of features to have it work accurately due to differing scale of plans.
