CSS Tool (Basic Problem)
Hi everybody, I need your help to fix a little problem.
I’m trying to create a progress bar with CSS tool. I defined a percentage for the width size of the element and created a workflow on page load. When the page is loaded, it first changes the width size but then it returns back to the normal size. Is there anything that I miss?
Here is the video of problem: https://drive.google.com/file/d/14C56SuVKJvLU5TdLSlFeG1F06eV386K5/view
Hi there,
This is hard to debug without seeing the CSS you’ve put in place.
Could you not use the Progress Bar plugin instead? It would integrate alot smoother with access via workflows.
