Currency conversion
hello i want to create a basic conversion system but im blocked ; i want that the user enter first is wage ,in second that he select a currency in the dropdown box ,and hten if he wants he can click the button which will change the wage in the converted amount
need to have an api to a currency converter
or need to store all the values that you would have to upload and update daily/hourly or however often you want the conversion to be accurate.
first need a data type of all currencies of the world with relation to their country
then need to have a data field for each currency of the world that shows a conversion percentage for each currency in the world
hello sorry for the late response i use my time to implement your solution, it works,thank you very much
