Hi guys, I’m having issus when trying to send the token to the reset_pw page.
Just some background: I’m making the process using SMS api instead email. I’ve created the logic to verify the code sent via SMS and redirect the user to the reset_pw page. When doing that, I’m creating the token (not sending email) , and then sending the user to reset_pw page with reset parameter as a result of the token creation step.
When testing, it says that the request in not valid.
Could you please help me on that? Thanks in advance.
