Datatypes created using SQL DB Connector
I am wondering if after creating data types with the SQL DB connector - after they are saved, do I have visibility of the schema of these types anywhere within Bubble. I’ve check the App Data and Data Type tabs and I don’t see any of the types that I have created. Thank you in advance.
Devon
No, you don’t. All you can do is map SQL data types from your query to Bubble data types.
Thanks Joey - appreciate it!
