Default values not working
Has anyone noticed default values not working? I tried to configure a yes/no statement and redirect the user to another page when the value changes, this feature is broken…
When the Current User verified is yes/no redirect to… it only works on page load when the value is correct, not in real-time when the user is on the page. I also tried the do every time statement…
This seems to be good, the default values are set only when the page is loaded.
However, if the value is changed in real time, you can trigger the ‘workflow’ on changed value.
I have used Do when condition is true workflow and set it to Everytime.
I’m not changing an input value so I don’t see a use case here for that workflow. Maybe I’m missing something here but this used to work.
