Design Problem section
below nav baar i have used 3 groups… one for white color and one for blue and i have to place an image of a car over them or between them, how can i achieve this ?
Just Add a image element in the middle group. Please be more elaborative
the image if placed over the groups in the design it is taking major portion of group A and some portion of group B
Make a parent group with container Layout to be Row (If you want horizontal)
Add Both the groups and the images inside the parent group
portion group B is color blue it is not getting visible over it … i want over it and the image is off a car… when i am using it in the parent container it’s size is too big
and i want the image to be less over group A and more on the group B
Can you add images of your current preview?
