Difference between text workflow navigation and link navigation
Is there any difference between:
A. Using a text element and workflow navigation to navigate to an internal page
B. Using a link element
A link is better if you can (meaning don’t have more actions in the workflow). It’s using the native browser links, so you can use right click, open in anew tab, and it’s a bit faster.
Ok. The things you mention I noticed.
Then I got it. Seems links are better. Big thanks!
Are there any limitation on the link options over the navigate option? i just want to make sure i’m using the right option for my situation
