Do every 5 seconds - first part
(Trying to use) Do every 5 seconds for testimonials showcase, have managed it to have them in a circle, but…
As “timmer” is 5 seconds, and the testimonials are on the Landing page (probably in the future .com), it seems that it takes for the “Do every 5 seconds” to trigger the first testimonial, i.e. first 5 seconds the “Testimonial group” is empty, whereas afterwards it goes a testimonial after testimonial…
How to “fix” those first 5 seconds of ironically-named ‘Do every 5 seconds’?
Just set the initial state of your testimonials on page load.
Yes, I have done that! Thanks for writing the solution!
Usually it’s simple at the end :slight_smile:
