Dropdown Values Are Not Separating
Hey guys, need a little help.
So I have a dropdown on my buy page that houses the size of the product.
View of the database
Screen Shot 2020-10-13 at 10.57.59 PM
I manually added this inside the database.
Screen Shot 2020-10-13 at 10.57.40 PM
Component ( the values should not be together.)
Workflow
Screen Shot 2020-10-13 at 10.57.21 PM
If you change your ‘Choices source’ in the dropdown to Search for Products productSizes, does it still behave in the same way? Your ‘Option caption’ I think will then become Current option’s text
Thanks bro. It works now.
no probs :slight_smile:
