You are using a Search to get the value, specifically the first item from the search and I imagine you have more rows then 1 in your database. Instead, change the parent group to the type : ˜SocialAssesment" then, in your workflow, add a new step: ‘Display data in group’ and display the results to the group.
Now you have access to the specific value you created, using ‘Parent SocialAssesment’
So sorry it doesnt work yet :(. Thanks for your response, i am doing what you recommend me . If you wanna another screenshor from any section, tellme, thanks.
Preview the page, generate the value again and post here what values the inspector is showing. Another thing, your user is logged in and has privacy rules? Which ones?
