Element border color
Does anyone know how I can change the border color of elements? It used to be blue, which was much more comfortable to work with. Now it’s light gray, and it’s really straining my eyes. Is there any way to change it back to blue? Thanks!
Are you talking about when an element is selected element in editor and bubble editor highlights it visually as the selected element or on your elements your users would see?
The border around the elements visible on the screen used to be blue, but after the update it was changed to light gray. This light gray border makes it much harder to see the elements, especially for people who spend long hours working in the Design tab.
As you can see, even after applying these settings, the Element Borders are still light gray.
Huh… you’re right. I was convinced that was the setting. I just changed it in my app as well, and it still behaves exactly the same.
Could this be a bug? @fede.bubble
Placeholder de Silvio Santos tá top :rofl:
Coloquei o Silvio Santos de placeholder pra dar sorte no negócio rsrs.
There really isn’t a way to change the Element Border color, and spending long hours working in the Design tab with these light gray borders is very tiring on the eyes.
there isn’t anything for that border color on bubble’s settings, maybe that’s something we request @fede.bubble ?
Checking with the team on this
