Filter Using Tags
I’m having trouble trying to do a search using a tag as the basis of a new search.
The main database has a Field PostTag (Related to Tag Table)
The secondary database that holds the Tag has a Field TagPost (Related To Post Table)
When a Post is uploaded to the database the tags are sent to the Tag Database.
When I call the Posts in a RG the Tags appear inside that RG in another RG set to Tags.
No problem there.
What I want to do is click on a Tag and a new RG shows only the Posts that contain the unique tag.
Could someone give me a lift with how to do this please.
Thanks
Al.
You can add to a DB of Tags a field Posts ( List of Posts), so when a user clicks that tag, a backend will call all posts related to this tag
At present my DB of Tags Fields for Posts is NOT List of Posts it is just Posts.
Thanks for the help. I will try again this time using a Field List of Posts.
It if works I will come back and mark your post as the solution.
Al.
here are an example
Working on your reply right now. Thanks.
