Filtering a repeating group using fields in two databases
Hi, Nice to meet u^^ i am now developing chatting app.
The database structure in Bubble’s no-code tool is defined as follows:
User
  • Name, Text
  • Contact, List of User
Chat
  • Chat-User, List of User
In the page of chatting list, RepeatingGroup display current user’s contact(list of users), but i want to list only contact which has not chatting room between current user and contact.
Suppose users A, B, and C have been created. If a chat room is created, the Chat-User field in the Chat data type contains values.
The expression for the RepeatingGroup’s data source to achieve this, Each Current User’s Contacts, RepeatingGroup is excluding cases where Chat-User matches the Current User and Current User’s Contacts
Plz tell me about RepeatingGroup Data source expression.
Thanks
Do a Search for the Users Contact List and then use the :filtered operator and the advanced constraint to structure the constraint that the Users Contact List is not in the Do a search for Chats each items List of Users.
Thanks your comment^^
I solved by below criteria(from your idea also). but i did’t fully understand
Current User’s Contact:minus list Search for Chats(Type:Chat Constraint:Chat-users contains Current User):each item’s Chat-users
Chatting Room is one for A,B
logined by A ( A has contacts B,C)
logined by C ( C has contacts A,B)
