First calculate, after update data thing with a one click
Hi bubblers, I am facing a issue with data changes because, I need to make a calculation and after save the data and now is saving the data before the calculation, the app is saving a blank.
My idea: when a truck driver click the button “start trip” the app save the current departure time and calculate the estimated arrival making a sum. Here is where I have the problem because when the button is clicked, save the current departure time and estimated arrival before make the calculation, so estimated arrival is blank is that moment. I need to click the button, make the calculartion and after save the changes.
Thank you,
Best regards
@025gerard You can use an API workflow for this where you pass the current departure time as a parameter and the calculation for estimated arrival runs in the backend and then saves to the database only when complete.
