Fix horizontal resizing handles to be in vertical middle, not lower
Currently the horizontal resizing left/right handles of elements are not in the middle of their bounding box, why?
They’re a bit lower (don’t suppose they show the text baseline or something? think they’re like that in all controls
This makes it harder to visually align a control to some text that is on its side. When the handle is in the vertical middle it makes it easier when you move/resize the control in relation to some text next to it, else it feels strange (makes you feel as if you have it misaligned)
Can you share a screenshot to show what you mean?
see “Reporter” checkbox. The middle handles for resizing are lower that they should be (should be vertically in the middle)
I see, thanks
