Focus group on a repeating group element
I cannot select element that is within the repeating group as a reference of my focus group.
As I have a button there that gives the user possibility to select wanted element and put it into this field.
How did you guys made this work in your apps?
/edited - previously put question about floating group instead of focus
Do you mean GroupFocus? (not floating group)…
Yeah of course, group focus. My bad.
You need to create a Reusable Element, containing the GroupFocus, AND the element you want it to attach to.
Then put that RE inside the RG.
Thanks. We will try to do this, thou I really don’t understand why this option is not available as a standard. Also will try if the conditionals/custom states work properly in that case.
