Fonts Stopped Rendering
All of the sudden my fonts stopped rendering on the application.
Has anyone experienced this issue?
Multiple computers and devices and it’s the same thing.
Does the client browser console give any indications? e.g. 404’s on any scripts/content, or is there any warning or exceptions listed.
Thanks I hadn’t thought of that. When I look, I see an error for mixed content, but can’t find out what script it is that is causing it:
It is telling you in the error message.
the file common.js in the chrome extension (you can use the chrome extension id shown to check against the tools extensions page in Chrome to see which one it is) is making an API call to an HTTP endpoint, check your api definitions it will be a should be a simple case of changing an API HTTP endpoint to HTTPS.
