Forum App Help Required - Topic - Comment - Reply - EDIT - SOLVED
Hi @fayewatson
I am trying to achieve similar thing which you have explained very well in this above forum topic.
I am applying same logic of commenting and replying for a topic which is of a repeating group cell data .
I see in database after entering comment in input box and press post button , the "Orginal Post " field in database is not saved.
The Orginal Post field should refer to Topic which is in that particular cell of Repeating Group…
EDIT :
I have pasted the image of workflow, in my case orginal post = Parent Group’s SocialComment’ Orginal Social Post.
Can anyone please help me.
Here is the link to my app
Thanks Arjun
whooo… i see even in debug mode the data is not seen
FYI… I am using RG
